thought you all might be able to help or walk me throught the set up for the maft pro or at least lead me in the right dicertion.
i have the maftpro hooked up with a lc-1 wideband and the map sensor and the ait and a boost controler all from the same place but the person i bought it from seem not to be able to tell me anything about how to set it up. i tried to talk to drjonz and didn't really get any where he was busy. so the thing is the car is a 89 turbo with a ct-61, 550 injectors,the j hook removed, 255 walbro, 2.5 hard pipes, 3 inch off the turbo back, and some other mods but nothing that effects the fuel. i want to be able to run around 12-15 psi and the car to run decent just ilding around i have no idea what numbers to set anything out or how to know to start can you help thanks very much.
