Car mod's
7MGTE engine rebuild .040
Walbro with 12v mod
FPR with vacuum at 28 Psi
RC 550cc Injectors
Q45TB
IC pipe 3”
AEM wide band
I instlla the Maft pro and upgrade the MaftPro software to Version to 4.8, then the Set up, but the option and display tags are different from the old version but I try to set up properly.
After the set up, I star the engine, but at Idle have problems L (I don’t drive the car) engine dies and the RPM’s are to low around 500 to 600. :aigo:
The MP is 90-93 with the engine off, when the engine is running is 30-33.
The AFR in the tuner pro is around 19 – 13, but in the AEM gauge in less that 18, because the display don’t show any number only ---. :cry:
I attach a ZIP with bin file of my setup and a record file with the engine running for your review.
I hope some can help me. :1zhelp:
Thank you all and best regards.
TunerPro Bin Data Export
Source File: PTR210 Test 01 July 23 '08.bin
Source Definition: TPro4600.xdf
Constants
Number of Cylinders 6
Displacement 3.00 Liter
Airflow Source 0x00 Select
Manifold pressure source 00
Vehicle Select 00
Density Comp Source 0x00
Barometer Comp Mode 00
Frequency Out Mode 0x04
V Out1 Mode 0 Select
V Out2 Mode 0 Select
AFR Source 3 Select
Freq In Mode 11
Aux 1 mode 00
Main Scale -10.00
Volts Out 1 Setpoint 2.45
Volts Out 2 Setpoint 3.53
Afterstart enrichment 1.00
Tune Load Point, Low 36.40
Tune Load Point, Mid 100.10
Tune Load Point, High 143.00
Freq Out Max 0
Timing Monitor, Base Adjust 0.00
Timing Monitor, Correction 1.27
AFR Tracking, Enable delay 0.00 Seconds
FE Smoothing 30
Boost control TPS Spool 2.50
Boost control RPM Spool 2400 RPM
Boost control TPS Start 3.40 Volts
Boost control PSI Start 11.00 PSI
Boost control DC% Start 60.00 Percent
Boost control PSI Set 14.00 PSI
Boost control PSI Aux 10.00 PSI
Boost Control Gain 8.00
Boost Control DC% Start Aux 10.00 Percent
Boost Control Max RPM 0.00
AFR Min TPS 3.00
AFR Min RPM 3200
AFR Min MAP 150.89
AFR correction lean limit 10.00
AFR correction rich limit 10.00
AFR correction gain 4.00
AFR Aux % 0.00
TPS Enrichment 0.48
TPS Decay 0.80
Throttle Body Size 8
TPS MAP Max 104.06
MAP Enrichment 0.40
Boost Enrichment 0.40
MAP TPS Min 0.40 Volts
MAP RPM Min 640.00
MAF Limit TPS Threshold 0.00 Volts
MAF Limit 0.00
MAF Limit / KRPM 0.00 Grams/Sec
Flags
Tables
AFR Tracking
AFR AFR
2000 3000 4000 5000 6000 7000 8000
A/F Ratio 11.50 11.50 11.50 11.50 11.00 11.00 10.50
VE table
MAP(Kpa) RPM
00 400 800 1200 1600 2200 2800 3400 4000 4600 5200 5800 6400 7000 7600
320 78.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
300 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
280 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
260 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
240 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
220 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
200 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
180 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
160 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
140 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
120 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
100 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
80 70.0 80.0 80.0 82.0 83.5 85.5 85.0 83.0 82.0 79.0 78.0 77.0 77.0 77.0 77.0
60 63.0 66.0 68.0 70.0 73.0 77.0 78.0 77.0 73.0 70.5 69.5 68.0 67.0 66.0 66.0
40 54.0 56.0 56.0 62.0 63.0 70.0 73.0 73.0 69.0 66.0 64.0 63.0 62.0 61.0 61.0
20 45.0 50.5 50.0 50.5 54.0 61.5 63.5 63.5 62.5 59.0 58.5 56.5 56.0 55.5 55.0
00 43.0 43.0 44.0 47.0 48.0 49.5 51.5 51.0 46.0 44.0 43.0 42.0 42.0 42.0 42.0
AF User Tune Hi
RPM
Percent 0.0 0.0 0.0 0.0 0.0 -13.5 -13.5 -15.0 -15.0 -15.0 -15.0 -13.0 -9.5 -6.0
AF UserTune Mid
RPM
Percent -17.0 -17.0 -17.0 -17.0 -17.0 -17.0 -17.0 -17.0 -17.0 -17.0 -17.0 -17.0 -10.0 -5.0
AF User Tune Lo
RPM
Percent -11.0 -11.0 -11.0 -11.0 -13.0 -16.0 -16.0 -16.0 -16.0 -16.0 -16.0 0.0 0.0 0.0
Aux Triggered tune
Percent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Air Temp Correction
degrees
-40.00 13.00 41.00 62.00 82.00 103.00 129.00 173.00 315.00
Pecent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Spark WOT
RPM
2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000
Degrees 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00
Spark Aux
RPM
Walbro with 12v mod
RC 550cc Injectors
Q45TB
IC pipe 3”
AEM wide band
Constants
Vehicle Select 00
AFR Source 3 Select
Freq In Mode 11
Aux 1 mode 00
Main Scale -10.00
Freq Out Max 0
FE Smoothing 30
AFR Min TPS 3.00
AFR Min RPM 3200
AFR Min MAP 150.89
AFR Aux % 0.00
TPS Enrichment 0.48
TPS Decay 0.80
TPS MAP Max 104.06
MAP Enrichment 0.40
MAP RPM Min 640.00
MAF Limit 0.00
Flags
Tables
AFR Tracking
AFR AFR
VE table
MAP(Kpa) RPM
AF User Tune Hi
RPM
AF UserTune Mid
RPM
AF User Tune Lo
RPM
Aux Triggered tune
Air Temp Correction
degrees
Spark WOT
RPM
Spark Aux
RPM
