I figured it out, with out changing parts. The connection from ecu to cps wiring was loose. I took the ecu apart and checked for cps ohms (inside the ecu) got 200 on one and flickering connection on the other two. Used a rubber band to hold them, so that they got connection (200ohms on both). Reset ecu and bam it's alive
