Maft Pro Tune Setups
dylansword
114
boise id
Hey everyone, Ive got the maft pro in my mkIII, and im having some trouble getting it tuned right so it will run smooth. So i thought id start a thread to see how people have their Maft setup, and what mods they have.
I have an 87 Turbo, with 3in exhaust and downpipe, fmic, walbro 255, Maft Pro and hardpipes.
Heres what ive got everything set at right not, and it has some issues with the idle and a stumble. (I Do not have a wideband installed)
Config
Vehicle Select 0
# of Cyl 6
Displ 2.96
Airfl Mode Speed Density
MAP Source GM 3 Bar
DENS Srce Use MAP
Baro Mode Sealevel
F Out Mode Supra MKIII
V Out 1 mde Set Max Setting
V Out2 Mde Set Max Settingt
AFR Source 5V AEM Guage
F In Mode Supra MKIII
Aux 1 Mode Aux Trig Off
Setup
Mainscale -10.00
V Out1 Set 2.500
V Out2 Set 3.600
Afterstart 0.0
Lo Load Pt 36.4
Mid Load Pt 100.1
Hi Load Pt 143.0
Freq Out Max 0
Timing Mon Base 0.00
Timing Monitor Corr 1.27
AFR Tracking Delay 0.0
FE Smoothing 00
Use VE Table #1
Spk Base 0.0
Boost Control
TPS Spool 2.000
RPM Spool 2400
TPS Start 2.800
PSI Start 13.0
DC% Start 50.00
PSI Set 13.0
PSI Aux 13.0
Gain 10.0
DC % Start Aux 10.0
Max RPM 0
AFR Tracking
Min TPS 4.9
Min RPM 3200
Min Load 166.4
Lean Lim% 10.0
Rich Lim% 10.0
Gain 4.0
AFR2000R 11.5
AFR3000R 11.5
AFR4000R 11.5
AFR5000R 11.5
AFR6000R 11.5
AFR7000R 11.5
AFR8000R 11.5
Aux % 0.0
Air Temp
-40.00 0.0%
13.00 0.0%
41.00 0.0%
62.00 0.0%
82.00 0.0%
103.00 0.0%
129.00 0.0%
173.00 0.0%
212.00 0.0%
Aux Triggered
All 0.0%
Tuning
RPM High Mid Low
400 0.0 0.0 0.0
800 0.0 0.0 0.0
1200 0.0 0.0 0.0
1600 0.0 0.0 0.0
2200 0.0 0.0 0.0
2800 0.0 0.0 0.0
3400 0.0 0.0 0.0
4000 0.0 0.0 0.0
4600 0.0 0.0 0.0
5200 0.0 0.0 0.0
5800 0.0 0.0 0.0
6400 0.0 0.0 0.0
7000 0.0 0.0 0.0
7600 0.0 0.0 0.0
Tune Response
TPS Enrich 0.40
TPS Delay 0.6
TPS Size 6
TPS MAP Max 104.0
MAP Enrich 0.1
Boost Enrich 0.1
MAP TPS Min 0.8
MAP RPM Min 2560
MAF Limit TPS Threshold 0.00
MAF Limit 0.00
MAF Limit/KRPM 0.00
Timing Monitor
Spark WOT Spark Aux
2000 0.0 0.0
2500 0.0 0.0
3000 0.0 0.0
3500 0.0 0.0
4000 0.0 0.0
4500 0.0 0.0
5000 0.0 0.0
5500 0.0 0.0
6000 0.0 0.0
6500 0.0 0.0
p7000 0.0 0.0
7500 0.0 0.0
8000 0.0 0.0
PT Tracking
Idle TPS 0.000
Idle RPM 640
Idle A/F 13.5
Cruise TPS 2.500
Cruise RPM 2560
Cruise MAP 91.0
Cruise A/F 13.5
Lean Delay 10.0
Gain 15.0
Lean A/F 16.0
topekamk3
72
Topeka, KS
If your afr source is the 5V AEM Gauge and its not installed that would mean the maft isn't getting that reading, which could be causing your problem.
kneedragger85
363
Boulder, CO
Make sure all your IAT, MAP, TPS etc readings/voltages are correct. I initially had an issure where the MAP sensor wasn't gettting a full 5 volts thus throwing off my tune.
