Just picked up a mkiv and wanted to take the maft pro out of my mk3 and install it in the mkiv. I just wanted to confirm first though that it will work. I think it could because I see mkiv guys running map ecu's and i know a few mk3 guys are as well. With that in mind the maft pro wiring is pretty similar to the map ecu.
I would much rather run the maft pro then blow 1g on an aem setup.
Any info is much appreciated guys.
thanks
thanks
