Maft pro question
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
ok i've been searching around the site for a day and a half now and cant find anything(well i been looking around the site but not searching specificly)
When you install the the maftpro does that get rid of boost cut or do you still need to buy a fcd
EdgeSupra
506
New Jersey
With the MAFTPro you can run on speed density and eliminate the need for the stock AFM. Hence, MAFT = Mass Air Flow Translator.
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I run 22-23 psi without fuel cut, any higher it hits. You can clamp it off like the fcd, but it doesnt add fuel after that. Im going to up fuel pressure a little, and do some more tweaking in the spring.
Doward
4,245
Alachua, FL
Unless I missed where the MAFT-pro does direct injector control, the MAFT-Pro will not increase FC automatically by itself, with no other changes.
You use it as a scalar with larger injectors, to deliver a lower air reading to the TCCS. This is how you get around fuel cut - or you can clamp it with teh MAFT-Pro.
