**Maft Pro Installers. What Vac line do I use?**
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
I am installing the Maft Pro (speed/Density) and I want to know what vacuum line do I need to use to connect the map sensor?? I wanted to mount it on the passenger side..
mhopemk3
Jul 13, 2005
762
Bishop92t said:
You can T off the BOV line. It just needs to be post throttle plate and not regulated by any VSV's.
I have the BOV line running from this hard line under the intake manifold. To the BOV.. So I can just T off of this??
Bishop92t
773
USA
www.ma70.com
Yes. Personally I'd install it on the intake manifold side as close to the manifold as possible. It's cooler on that side and there's less chance of a vacuum line mishap. If you accidently attach the BOV line to the incorrect spot in the future it could cause your car to not run or not run properly.
