When a MAFT pro is installed for the first time running speed density, and all the initial parameters have been set does it need anything else to run correctly?
For an example, when I installed my VPC I turned the car on, adjusted the idle knob and went, it ran great.
After the correct parameters for the MAFT pro are setup, and the wiring is finished, what will need to be done, if anything?
One other thing. I remember reading a while back that all the abbreviations where going to be eliminated and replaced by the full word. Ex. Fin, Fout, etc. Did that happen yet or not?
