latest *.bin file attached with *.xdf and *.adx. I think my biggest issue I was having is trying to tune the car while it was 40 degrees out. I did the resistor mod in my MaftPro install telling the stock ECM that it was 70ish. Tuned the car when it was 68 degrees out and stuff actually made sense.
TABLE: AFR Tracking
AFR AFR
2000 3000 4000 5000 6000 7000 8000
A/F Ratio 12.50 11.50 11.50 11.50 11.50 11.50 11.50
SCALAR: Vehicle Select 00
SCALAR: Number of Cylinders 6
SCALAR: Displacement 2.96 Liter
SCALAR: Airflow Source 0x00 Select
SCALAR: Manifold pressure source 03
SCALAR: Load Source 0x00
SCALAR: Barometer Comp Mode 01
SCALAR: Frequency Out Mode 0x04
SCALAR: V Out1 Mode 0 Select
SCALAR: V Out2 Mode 0 Select
SCALAR: AFR Source 3 Select
SCALAR: Freq In Mode 0
SCALAR: Aux 1 mode 00
SCALAR: Main Scale 0.00
SCALAR: Volts Out 1 Limit 0.00 volts
SCALAR: Volts Out 2 Limit 0.00 volts
SCALAR: Afterstart enrichment 10.00
SCALAR: Tune Load Point, Low 36.40
SCALAR: Tune Load Point, Mid 100.10
SCALAR: Tune Load Point, High 143.00
SCALAR: Freq Out Max 0
SCALAR: Timing Monitor, Base Adjust -10.00
SCALAR: Timing Monitor, Correction 1.27
SCALAR: FE Smoothing 30
SCALAR: Boost control TPS Spool 1.00
SCALAR: Boost control RPM Spool 992 RPM
SCALAR: Boost control TPS Start 2.00 Volts
SCALAR: Boost control PSI Start 6.00 PSI
SCALAR: Boost control DC% Start 65.20 Percent
SCALAR: Boost control PSI Set 10.00 PSI
SCALAR: Boost control PSI Aux 11.00 PSI
SCALAR: Boost Control Gain 10.00
SCALAR: Boost Control DC% Start Aux 0.00 Percent
SCALAR: Boost Control Max RPM 7488.00
SCALAR: AFR Min TPS 1.20
SCALAR: AFR Min RPM 2016
SCALAR: AFR Min Load 40.32
SCALAR: AFR correction lean limit 2.00
SCALAR: AFR correction rich limit 6.40
SCALAR: AFR correction gain 10.00
SCALAR: AFR Aux % 0.00
SCALAR: AFR Tracking, Enable delay 0.00 Seconds
TABLE: VE table
MAP(Kpa) RPM
00 400 800 1200 1600 2200 2800 3400 4000 4600 5200 5800 6400 7000 7600
320 78.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
300 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
280 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
260 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
240 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
220 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
200 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
180 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
160 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
140 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
120 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
100 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 91.0 90.5 90.0 90.0 90.0 90.0
80 70.0 80.0 80.0 82.0 83.5 85.5 85.0 83.0 82.0 79.0 78.0 77.0 77.0 77.0 77.0
60 63.0 66.0 68.0 70.0 73.0 77.0 78.0 77.0 73.0 70.5 69.5 68.0 67.0 66.0 66.0
40 54.0 56.0 56.0 62.0 63.0 70.0 73.0 73.0 69.0 66.0 64.0 63.0 62.0 61.0 61.0
20 45.0 50.5 50.0 50.5 54.0 61.5 63.5 63.5 62.5 59.0 58.5 56.5 56.0 55.5 55.0
00 43.0 43.0 44.0 47.0 48.0 49.5 51.5 51.0 46.0 44.0 43.0 42.0 42.0 42.0 42.0
TABLE: AF User Tune Hi
RPM
Percent 0.0 0.0 17.0 17.0 17.0 17.0 17.0 18.5 18.5 18.5 18.5 18.5 18.5 18.5
TABLE: AF UserTune Mid
RPM
Percent 0.0 0.0 14.5 18.0 18.0 19.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0
TABLE: AF User Tune Lo
RPM
Percent 25.0 25.0 15.0 10.0 3.0 3.0 3.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0
TABLE: Aux Triggered tune
Percent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
SCALAR: TPS Enrichment 0.50
SCALAR: TPS Decay 0.80
SCALAR: Throttle Body Size 7
SCALAR: TPS MAP Max 230.24
SCALAR: MAP Enrichment 0.30
SCALAR: Boost Enrichment 0.30
SCALAR: MAP TPS Min 0.50 Volts
SCALAR: MAP RPM Min 640.00
SCALAR: MAF Limit TPS Threshold 0.00 Volts
SCALAR: MAF Limit 0.00
SCALAR: MAF Limit / KRPM 0.00 Grams/Sec
SCALAR: MAF Limit RPM Min 736.00 RPM
SCALAR: MAF Limit Time 0.30 seconds
SCALAR: Part Throttle Tracking Idle TPS 0.54
SCALAR: Part Throttle Tracking Idle RPM 800.00
SCALAR: Part Throttle Tracking Idle A/F Ratio 14.70
SCALAR: Part Throttle Tracking Cruise TPS 0.74
SCALAR: Part Throttle Tracking Cruise RPM 2944.00
SCALAR: Part Throttle Tracking Cruise Load 39.02
SCALAR: Part Throttle Tracking Cruise A/F Ratio 13.50
SCALAR: Part Throttle Tracking Lean Load 22.11
SCALAR: Part Throttle Tracking Lean Delay 0.00
SCALAR: Part Throttle Tracking Lean A/F Ratio 14.00
SCALAR: Part Throttle Tracking Gain 15.00
SCALAR: Part Throttle Tracking Startup Delay 0.00 Percent
SCALAR: Enhanced TPS RPM threshold 2720.00
SCALAR: Enhanced TPS Load Threshold 106.67 KPA
TABLE: Air Temp Correction
degrees
-40.00 13.00 41.00 62.00 82.00 103.00 129.00 173.00 315.00
Pecent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
TABLE: Spark WOT
RPM
2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000
Degrees 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00
TABLE: Spark Aux
RPM
FUNCTION: Custom Voltage MAF
Index Volts Grams/Sec
40 0.12 0.52
39 0.16 0.53
38 0.31 1.28
37 0.47 1.59
36 0.63 4.52
35 0.78 7.52
34 0.94 10.05
33 1.09 14.66
32 1.25 21.50
31 1.41 27.75
30 1.56 38.50
29 1.72 49.25
28 1.88 64.86
27 2.03 83.35
26 2.19 101.50
25 2.34 118.05
24 2.50 142.06
23 2.66 171.46
22 2.81 210.32
21 2.97 242.60
20 3.13 288.50
19 3.28 345.69
18 3.44 402.54
17 3.59 461.57
16 3.75 526.49
15 3.91 597.59
14 4.06 675.21
13 4.22 759.71
12 4.38 851.43
11 4.38 851.43
10 4.38 851.43
9 4.38 851.43
8 4.38 851.43
7 4.38 851.43
6 4.38 851.43
5 4.38 851.43
4 4.38 851.43
3 4.38 851.43
2 4.38 851.43
1 4.38 851.43
TABLE: VE Table MAP axis
KPA
(null)
320
300
280
260
240
220
200
180
160
140
120
100
80
60
00
TABLE: VE RPM Points
1 2 3 4 5 6 7 8 9 10 11 12 13 14
(null) 0.00 400.00 800.00 1200.00 1600.00 2200.00 2800.00 3400.00 4000.00 4600.00 5200.00 5800.00 6400.00 7000.00 7600.00
View attachment MaftProFiles.zip
