mafs
toyotanos
What will we break today?
2,841
Coon Rapids, MN
Oh my...
3 major options:
1- Maft Pro
2- HKS alphabet soup (VPC namely, others may be needed as well)
3- Standalone in Speed-density mode.
That's organized from cheapest to most expensive...
You can find used maft pro's for 500 and then havfuel control, timing control, boost control, and wideband.
Or you can get the standard maft for 400 new and run speed density.
Or you can get the maft gen II and run the gm blow through sensor and just mount the sensor somewhere in the ic piping.
There good systems and there newer and better updated than the old hks stuff. Esp the maft pro because then you having timing control.
