maf pro questions
polobai
Orlampa
i am not about to read that 800 page thread to find this out-so does anyone know if the yellow wire on the MAF pro hooks up to anything? It doesnt in any of the wiring diagrams, but just want to make sure. Also does any one know the description of the resistor needed and its placement on the afm harness so no CEL is thrown?
chriso
Supranian
Bay Area, CA
Yellow wire doesn't go to anything. Also, you can connect a 2.2 ohm resistor between the terminals THA and E2 of the loose AFM connector in the engine bay or at the ECU to eliminate the Air Temp code.
