Ok so I can't get my car to run quit right. Here are the symptoms.... 1st Lumpy idle and almost sounds like an inconsistent miss, when this happens the afr jump to 16-17 lean( otherwise it idols with a 14.5-15.5 afr). 2nd at idle I have only 14 lbs of vacuum on the boost gauge. 3rd under boost the wants to go lean towards 13.5afr and rarely gets to 10.5 or 11 unless it's the first pull on the engine once it's warm then it progressively gets leaner and leaner each time under boost. Side note also while under boost the engine seems to break up and stutter then slams back into boost.
As of now I have pressure tested the system with no leaks up to 10lbs ( I'm only at 8lbs) and I also did a smoke test with no leaks at all. So for now I'm ruling out a vacuum leak. I'm working on rigging up a fuel pressure gauge to see if my fuel pump is going bad.
Here are my current mods... Rebuilt motor with eagle hbeam rods, probeforged pistons .02 over, balanced rotating assembly, ct-26 57trim, front mount intercooler kit with factory recirculation valve, BC 264 cams with titan adjustible cam gears, and I believe it's Arizona speed upgraded oilpump, oh and full 3angle valve job with BC valvesprings and retainers. Everything else is stock.
I also tester thi iac and set the tps. Car seems to drive fine other wise. I had to advance the exhaust cam and retard the intake to get ride of some overlap to get it to idle at all but it starts up fine and drives fine without boost but I don't like to drive around like I sit down when I pee so this is really bothering me lol😂😂 If anyone has any input it would be great!
