lucas 550 injectors
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
will these injectors work on our car? or fit for our car..i got 6 from a local performance shop for free..the guys told me they are 550cc and will fit on our cars..but i forgot to ask what car they came out of..there are some numbers on it..
where the clip attaches it says - "927"
right next to it - "0280150756"
right under the green rubber thing on top - "1012"
hope the info i gave helps
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
As long as they're top feed and low impedence, you should be good. Did they come with clips or are they suppose to work with the factory ones? Either way, I'd have them properly flow tested before I would use them.
figgie
Twin Cities, Minnesot-ah
well keep in mind.
The toyota NipponDenso injectors use a 11mm top feed
Most Bosch and Domestic injectors are 14mm top feed.
Lucas = the old name for Delphi before the split off from GM (also known as Rochestor).
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
ill take a pic ounce my sis gets home..and post it up..hopefully that will help a lot more..you guys know where to flow test..besides rc?? somewhere affordable kinda low on the cash..cause of school
MKIIINA
Destroyer of Turbos
Plano, TX
at a min i would get them flowed and cleaned before you even thought about putting them in a car or selling them. you could probably easily sell them and use the money for some mk3 specific injectors if need be.
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
thats the picture..sry ima noob in fuel mods..don't know what top or bottom feed is..=[
figgie
mk3concepts;1110409 said:
ic ic..thanks..so we can use that injector on our cars right? just gotta get it cleaned and flow test and get clips?
no.
You have to verify that they are infact machined for our cars. Stock Delphi/Lucas/Rochestor injectors were made for Domestic cars which means a 14mm top feed NOT 11mm. That why you VERIFY with a set of calipers at the least.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Don't even think about trying to bore the fuel rail to take those injectors yourself either.
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
nah i know what im doing..and no im not going to bore the fuel rail..im asking these questions to make sure im doing the right thing..the injectors are just sitting in the garage till i find out if they fit or not
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
i think trial and error may be a better way for you to learn than asking questions....as the answers given in this thread are extremely simple to understand.
