does anybody know what the best oil to use in the las rear end 89 turbo. i havent been able to find it anywhere.
jamesmwalker79;1546501 said:does anybody know what the best oil to use in the las rear end 89 turbo. i havent been able to find it anywhere.
livinasask8er;1546549 said:Well the manual says straight 90w, but I couldn't find any (and I was told it wasn't made anymore, might be bs though), so I gave up and put 80-90. I don't know if I'm taking a risk in the weight that I chose, but what I can tell you is that you need to make sure it's for lsd hypoid gears, and that it has nothing else added.
Poodles;1546618 said:Try digging around in here: http://www.supramania.com/forums/forumdisplay.php?108-Motor-Oil-Lubricants-amp-Filtration
speedgilligan;1546651 said:when i did mine, ALLDATA suggested 75w-90 or GL-5 and that what i did
jdub;1546773 said:(...)
I don't know what manual you are looking at, but the TSRM and the car manual says 80W or 90W depending on OAT...it allows the use of 80W-90:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=A&P=35
This is 20+ year old data (for a 1990). Modern LSD gear oils are far superior and will be a multigrade 99.9% of the time - even mentioning a straight grade is useless. IMO a 75W-90 is what you want to use.
livinasask8er;1546884 said:I'm gonna ask for a tsrm.
