Allright so I did some tests.
1. Both wheels up. Car in neutral. I spin one wheel the other turns the same way. (So I do have LSD)
2. One wheel up. Car in neutral. The wheel spins without any bit of resistance (wtf)
3. One wheel up(on floor jack with wheels). Car in first gear. At 1000 RPM the wheel spins freely.(WTF?!) I dont want to rev it higher since I dont want it to lock and launch it in the living room.
So basically I guess my plates are beyond worn. Where can I get clutch plates? Is it dealer only?
EDIT
So I have been doing some reading on these LSDs. I guess it makes sensee why 1 and 2 came out the way they did. Without much torque they don't lock. Come to think of it my LSD only slips initially then it stops. I guess new shims would help.
Also I think it slips more in cold weather than in warm weather. Is that possible? Why?
Is there any way to test the clutch? I will take it out to install new shims, but I would like to know beforehand if I need new plates too, so I can order them in advance.
Thanks guys
