Alright, I'm seeking advice for myself and BryanDyer... seems we're both having similar (if not the same issue)
low throttle input hesitation, general unresponsiveness. (should note my tach is off quite a bit too) Any input as to what could possibly cause this is welcome.
both of us have working TPS set to TSRM spec. I set my ignition timing to spec. (was @ 0 degrees) changed my spark plugs and gaped them appropriately.
I plan on checking out my CPS and igniter once I get the car back (getting exhaust fabbed, since it had just a DP). I'll probably check out the coils as well, and the wires. I'll also be checking for any loose connections.
I was also thinking of cleaning out the AFM, but I was under the impression that you're not supposed to do that.
before anyone asks, my car is not throwing any codes
Anyhow, thanks in advance for any input... it'll be a slow work in progress.
