Low oil pressure? Turbo?
MK3Supraman
67
olathe,ks
ok so im reading 40 psi oil pressure at 3k COLD
then when it warms up im barely hittin 38 psi warm
i do have oil in my ic piping and full boost im hearin a loud like supercharger whine from the turbo. but would this cause low oil pressure?
i was under it and my oil pan looked like it domes up like a bottom of a pop can but no marks? is this how they are suppose to be??
lmk before i go upgradin and blowin a rod bearing
**valve cover gaskets replaced and new grommet seals so no oil leakage there:naughty:
rayall01
901
Westfield, ma
Is your oil level going down? The pressure you're getting seems typical for MKIII's. As the oil heats up, it flows much easier, and pressure will drop significantly from cold readings. As for the whine, your turbo bearing may be shot. Take off the accordion pipe, and check the shaft for excessive radial, and axial play. Try turning the shaft as you move it, and if the compressor, or turbine blades start dragging on the housing, you definitely need a turbo.
MK3Supraman
67
olathe,ks
very slowly when my valve cover gaskets were shot and i havnt checked since i just changed that and my oil today ill keep looking and hit back up
is the oil pan suppose to dome i couldnt find pictures lol
also no smoke out exhaust so idk if that oil in the ic pipe is makin it to my cylinders?
grimreaper
2,180
Dallas
or blowby which is normal to an extent.
mY stock gauge read very similar numbers to yours. Aftermarket reads a LOT different and the mechanical one matched the aftermarket.
It should be noted the stock one is good for developing a "norm". If you want to be accurate put a mechanical in there for testing.
wizeguy707
22
Texarkana, TX
I experience the same symptoms. Let me ask you this. Pay attention to your oil pressure and cut your a/c on full blast. Notice a more than 5 psi decline?
92nsx
2,957
Clearwater, MN
Oil pressure sounds like normal for a 7mgte. As for the the oil in you IC piping Im sure it is coming from a bad oring or seal in the turbo. If it is a light coating I wouldnt worry to much about it. Just check you oil before every time you drive.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Here's the TSRM spec for engine oil pressure:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=LU&P=4
Note the troubleshooting chart on the above page.
Yours is a touch low, but still in spec...a couple things to consider:
- The cooler circuit relief valve on the side of the oil filter housing. It should open at ~40 psi to send oil to the cooler...it's possible the spring is worn and it's opening early.
- The piston oil squirters also open at ~40 psi.
- The oil pump pressure relief valve spring is worn and opening at a lower pressure.
If your oil pan has a dome shaped dent in it, then something has hit it. The oil pump pick-up is in that area.
