Installed the perma cool kit with out at the block going to in at the new filter relocation adapter, then out of there to the cooler then out of the cooler to in on the block. Now I only see 20-23 psi on gauge at 3k and about 8-10 at idle. Double checked the connections and used 1/2 inch aeromotive push-lok hose and 6-an fittings.
I had the standard 40 psi at 3k and maybe 10-15 at idle before this install.
Kinda baffled, wondering if oil pressure sending unit decided to take a shit during this install, doubt it because it is working sorta.
Any thoughts would be helpful.
Wayne
Wayne
