DONT PANIC!
...at least, i hope not!
Started the Supe today to bring it back from a friends house, and after about 1/2 a mile, i noticed that the oil pressure was odd. It was 20psi, but barely going any higher. It was also a bit rattlier than usual from cold. I decided to baby it into town and get some more 10w40. What did i find when i got there? I was 2 and a half litres OUT. My friend pulled in behind me and told me that i'd been leaving small dribbles of it behind me (we were in a convoy). BOLLOCKS!
Checked the top end, and theres no oil filling the gallery, none dripping out of the cam cover, and it looks like the oil cooler (13 row mocal) is okay.
Could this be rear crankshaft oil seal?
And even with me refusing to exceed 2000rpm into town - have i likely fecked my bearings? After putting more 10w40 in, pressure was back up to normal - 38psi @ 2500rpm, 41psi @ 3500+rpm. I only used it to get home, no further. The infamous 'clack' of rod knock was NOT there.
It's parked in my hanger, on concrete, and will go out and check in an hour to see if i have any puddles under the car, or if it's only pumping it out under pressure.
What was curious, is that the lid of the power steering reservoir had a little dribble/pool of oil over it. As my CPS has no cap (ordering a new one), i've thought that it MAY be coming from that, and the shaft bearing is buggered (i know for a fact it had a new O-ring in November). It could be that as well...but EESH.
