I took my car over to a mechanic friend of mine so he could look it over and double check everything since this is my first BHG job. After replacing the HG and putting everything back together, the 1st and 5th cylinders are getting very low compression and won't allow the car to turn over. I have read a little bit and what I have read is that it could be as minor as the head bolts not torqued down tight enough, or as major as the seals, rings being bad, or a valve is either bent or sticking. Any input would be greatly appreciated!
