I am having a low boost pressure problem that I cant seem to find to save my soul. Was hoping some of the experts on here might give me some insight on where to look next.
Current state -
Car has fresh stock turbo rebuild
Car runs and idles perfect.
Boost pressure is reading at 2psi on aftermarket gauge.
Things I have tried -
New intercooler hoses. (Minus the one directly off the turbo outlet - this is my next point of attack)
Vacuum lines have all been checked and no leaks have been found.
installed an MBC and tried to get the boost to go up with that - no change.
Things I know I need to check -
The BPV - Where is this located? I know I need to change the hose that comes off the outlet of the turbo, is it located there? (that is where it is on my MR2)
Heater controll valve - does this send any kind of signal to the ECU that might keep the car from running full boost before the car is running at full operational temp? My heater valve is cracked so I by-passed it.
Any help or insights you can give would be much appreciated, getting frustrated with this real fast.
Thanks,
CJ
Current state -
Thanks,
CJ
