Loud pop
Jay633
Hueneme Bay,Ca
Hi,I recently replaced my ct26 and after finishing, I started turning The motor for oil to pass through the turbo. Car suddenly turned on and I immediately turned it off. Cranked it once more and a loud pop was heard from the back off the exhaust, any suggestions on what it is or what I should do?
toyotanos
What will we break today?
2,842
Coon Rapids, MN
I'd guess it was built up fuel in the exhaust that popped when the engine fired on the second crank. Nothing to worry about imo, just be sure to double-check everything before running it!
Jay633
Hueneme Bay,Ca
I hope it is that rather than a problem. How can I pass oil through the turbo easier than cranking it. I don wanna run the worry of turning it on once more
toyotanos
2,842
Coon Rapids, MN
If you just want to prime the oil system, I suggest pulling the 'EFI' fuse out of the engine bay fuse panel. Car can't start without it :)
toyotanos
2,842
Coon Rapids, MN
Yep. Anytime I start an engine dry/after its been stored a while, I crank it (pull the EFI fuse) until I see my oil pressure gauge start to go up.
