Hey guys, I just got done with a mild rebuild (catch can, new IC pipes, relocate the power steering, etc) It started right up....and it seemed like it was running fine. Then I drove it for a while and the bird cage (BHG) light comes on. I pulled over and looked in the overflow reservoir, and it was almost empty. There was coolant all over the intercoler and the reservoir. So i pulled over and added coolant to the reservoir and to the radiator, it went away instantaneously. So I kept driving for about 10 minutes and then lit up again. Again I pull over and the same thing happens.... I never had this problem before..... I noticed that even at idle the coolant is dripping through that little hose from the reservoir tank. Any ideas ???? help or suggestions are always appreciated!!! Thanks
