ok guys i went to change the alt. the other day, and when i pulled it off i found 3 loose wires hanging behind where it mounts. one is brown and the other 2 are red and blue. they seem to run back into the wiring harness that runs across the valve covers. i dont have a camera right now but any ideas? also the oil return tube that runs from the valve covers to the pan was bent so far it was kinked. im going to have to get a new one i guess. its gotten so soft that it just kinks all the time when you bend it the least little bit.
