I Just got supra a few weeks ago but with the oil leaks and burning oil and low compression numbers I'd like to start looking towards my next motor for this car.
I pulled a 102K 7mge last year and its sitting in my garage.Im fine with staying N/A, More of just wanted a good running motor without issues of an old one and maybe a few hp goodies as well.
But I've been looking at a 2jzge that came into the junkyard about a week ago.[$220.00, I pull it]
For staying N/A and wanting longevity and maybe a ball park goal of 250 hp at the crank.
I know the 2jz would be easier to meet the hp goals, But is it worth the troubles of the swap ?
The build will go the same for each motor.
- strip down of the entire motor
- new rings, bearing, higher compression pistons - 0.20 over
- New oil pump, water pump, Timing belt etc
- 3 angle valve job, minor P & P, re-assemble
- Possibly a more aggressive cam
- copper HG
- aftermarket headers, cam gears.
- ARP hardware in everything
- balanced, blue printed, knife edged crank.
You get the picture, Basic rebuild with some goodies.
Obviously since the 2jzge has 26 more hp at stock the 2jz would be
easier for HP goals but Just more worried on how plug n play the wiring harness would be.
- copper HG
