oscolivar1 said:
uke:
I second Swaq.
Dell is a POS. Simple as that. They're cheap, but its for a reason.
I own a pretty new Powerbook G4 10.4.x and Sony Vaio XP Pro Desktop.
They both have their pros and cons.
PC Pros:
- Easy to upgrade on your own, tons of choices for components
- Don't need much expertise to work on them
- Lots of programs readily available
- Larger market share, so more support as well
- Vista to be released soon. I have the Beta waiting to be installed, haven't gotten around so iono if its worth all the hype
Mac Pros:
- UNIX-based, OS fairly stable.
- Lots of eye-candy, and more intuitive and well thought UI
- Everything really truly does just work. After I config'ed a print server on my network on the host PC, it took me a good 1.5hrs to get my PC to connect to the damn thing w/ 3 million errors. Took the Mac about 4 minutes. Same story with every other device.
- Much less chance of getting a virus
- Faster w/ less power
- iLife is FTMFW!!!
PC Con's:
- Less secure. More market share not only means more support, but more viruses built for the platform
- Nothing works the way it should. I don't care if you follow the directions verbatim, you will still end up w/ some problem more often than not
- Less stable
Mac Con's:
- If you want to buy a program you actually have to *look* for it
- DAMN expensive to fix. DON'T buy an Apple w/o Applecare, you will be screwed when something breaks. ::experience speaking::
- You really can't upgrade them yourself, its practically impossible to get parts, and when you do its nutty expensive.
- They DO crash-just not as often. No computer is flawless (acquaint yourself with the term "kernel panic")
That said, as far as PC's, I would only build my own, none of the desktop makers are any good, unless you want to pay double what you should and get a Sony. For a laptop I would only buy Toshiba, Fujitsu, or Sony (in that order). ABSOLUTELY DO NOT BUY DELL. Aside from their cheap components, I would rather deal with Satan and his demons than their customer service. They are completely incapable in tech support, and have terrible customer service.
So, by your list of wants, I would say go with the Mac. They are VERY compatible with PC's, and OS 10.4.x is beautiful. For pictures, movies, music, office work, Mac is hands-down better. Adobe CS2 is much better to work w/ in Mac than PC, the pallets are laid out more cleanly and such.
EDIT: Again to second what Swaq said, they are also very easy to pick up. The UI works identical to PC's if you don't get freaked by the minimize buttons being on the left and your programs down at the bottom of the screen. Other than that its very similar.
