After you went through the drill bits on the dowel on the gear, and you are peening it out, if you try and rotate the rod assembly does it now hit the g1 and g2 pickups and not turn completely?
I'm not sure if i bent it or not because I can't tell with my eye but this happened with both of cps's today.
On the second one I tried to avoid this, so I drilled a 2mm hole ALL the way through, drilled both sides of the gear, hit it with a blowtorch and tapped lighter and the dowel would not even budge and then i noticed the same thing as before. The rotating assy now does not rotate freely and hits the pickups.
:: angry ::
:: angry ::
