I don't know how much power you're pushing but beware that the 7mge 5spd (w58) won't hold as much power as the 7mgte 5spd (r-154), although it should still hold 350-400 as long as you aren't beating it to death. You're gonna need the driveshaft from the w58, tranny to engine brackets, clutch master cylinder, slave cylinder, hard line, soft line, a clutch, flywheel, throw out bearing (release bearing), clutch pedal, 5spd brake pedal...and maybe a few other things (can't think of anything right now). You shouldn't have to swap the LSD though.
