Does anyone which circut stays constant hot, 12 volts only after the car has started and off when the key is off??:3d_frown:
hvyman;1240855 said:what are you doing? why not just run off the batt. same thing.
Justin;1240865 said:What are you trying to power?
What you're looking for can be found in the ignition harness in the steering column, the cig. lighter, the radio, several places....
jdub;1240915 said:
tissimo;1240997 said:If you do this Make sure you have the 12v mod done @ the fuel pump relay so your relay wont be tripping the fuel pump resistor on.
