Hey Wiisass, guys,
I am running Tein Flex coilovers, which in my opinion are the perfect balance of good handling while retaining comfort. The spring rates are about 50% higher than stock(12kgf/mm 670lbs/in front, 6kgf/mm 340lbs/in rear) and I want to minimize body roll and maximize handling with a set of sway bars. My car is a widebody and my low-offset wheels make the front wheelbase about 4" wider than stock, and the rear 6" wider. My tires are the best performance tire BF Goodrich makes, the G-force KD, 245 18" front, 295 18" rear. These tires are quite aggressive, with a very stiff sidewall.
I am keen on the Whiteline sways, as they have 3 different settings to experiment with. I am also interested in the ST bars, but don't know their rates.
Assuming that the whiteline bars are the stiffest, I want to make sure I don't go too stiff, as I know this will overload the outside tires under heavy cornering and reduce traction on the inside tire. I just want to find the balance that gives me the absolute best traction around corners.
Also, I have an EDFC controller to adjust my shock damping rates front and rear. Is there an info page or tutorial on how these settings affect handling, and what kind of difference it makes when the front is stiffer than the rear or vice versa? I'm assuming there is a sweet spot setting of ideal handling, but I'm not sure how to dial it in.
Thanks for the help!
