Just got my LM-1 today and this thing is awsome! I made a few pulls and checked out the data on my home comp. I have a few questions for anyone that has used this . I have the LM-1 with the RPM convertor and inductive pick up. And I have the ability to modify the fuel mixture via fuel comp. and lexus screw
Question#1 What should my afr be at idle im at 14.5ish area right now
Question #2 When I let off my AFR goes nuts (lean)
I was told this is normal how lean is it actually going and does this hurt the engine?
Question#3 At WOT under load my AFR is in the 9ish where should I be to be safe I know this is alot rich
Question #4 The RPM data is a bit sketchy when I got it back to my home comp I can smooth it out with the software but is this because Im using the inductive pick ? Would it be better if I hard wired this RPM pick up ,if so where do I wire it into?
Thanks
Thanks
