little help with hw
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
little stuck on these problems, any help would be awesome.
Two cards are dealt off the top of a well shuffled deck. You have a choice:
(a) To win $1 if the first is a king.
(b) To win $1 if the first is a king and the second a queen.
Which option is better? Or are they equivalent?
For credit, justify by showing what is the probability in each case.
problem 2
Four cards are dealt off the top of a well shuffled deck. You have a choice:
(a) To win $1 if the first card is a club, and the second a diamond, and the third is a heart, and the fourth is a spade, in this order.
(b) To win $1 if the four cards are of four different suits, in any order.
problem 3
A consumer organization estimates that over a 1-year period 17% of cars will need to be repaired once, 7% will need repairs twice, and 4% will require three or more repairs. What is the probability that a car chosen at random will need
(a) no repairs at all?
(b) No more than one rpair? (hint: this is the same as: probability of one repair or no repair).
(c) Some repairs? (hint: this is the same as: probability of once, or twice, or three & more)
thanks
flight doc89
Registered Murse
Apr 21, 2006
227
Bessemer, Alabama, United States
Answer is A: Probability = (4/52)
4 kings, 52 cards
reason why A: for (b), probability is (4/52)*(4/51)
4 kings, 52 cards, after that first card is drawn, still 4 queens, but only 51 cards
problem 2
Probability of (a) and (b) = (13/52)*(13/51)*(13/50)*(13/49)
problem 3
(b) No more than one repair? (hint: this is the same as: probability of one repair or no repair).
Is that the exact wording? Does your teacher like trick questions? I ask because none of the questions have a time-frame.
Assuming it's not a trick question:
(a) = (72/100)
(b) = (89/100) or (72/100)+(17/100)
(c) = (28/100) or (17/100)+(7/100)+(4/100)
thanks
reply in bold. if i made a mistake somewhere, someone correct me.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
1- A, 1/13 vs (1/13)*(4/51)
2- B, don't feel like figuring out probabilities here.
3- A) 18/25
B) 89/100
C) 7/25
I say B on 2 because in B the first pull is a guarantee, in A it must be a club and therefore is a 1/4 instead of a 1.
EDIT: I'm a dumb ass there are only 13 cards in a suit lol
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
Canada has two official languages, English and French. Choose a Canadian at random and ask, “What is your mother tongue?” Here is the distribution of responses, combining mny separate languages from the broad Asian/Pacific region:
Language
Probability
English
0.59
French
0.23
Asian/Pacific
0.07
Other
(a) What probability should replace “?” in the distribution?
(b) What is the probability that a Canadian’s mother tongue is not English?
(c) What is the probability that a Canadian’s mother tongue could be either English or French?
just wondering if i did this right
A - .59+.23+.07 = .89 .89/3 = .296....7
B - .59+.23+.07+.29 = 1.18 ...... so .59/1.18 = .50
C - .59+.23 = .82 .82/1.18 = .69
Did i do this problem right ??
Sil
Evil Empire
Jan 13, 2008
340
Milwaukee/Chicago
Aren't these binomial and geometric probabilities? I should know as I just took the exam for it last week, but I'm too damn lazy to go look in my notes for the plug and play formulas.
flight doc89
Registered Murse
Apr 21, 2006
227
You are right, i figured it wrong.
Probability of (a) = (13/52)*(13/51)*(13/50)*(13/49)
Since it doesn't matter what the first card is, it becomes (52/52)*(13/51)*(13/50)*(13/49)
answer is B
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
anyone know what this is asking for
im so lost on this question
“You want to determine the best color for attracting cereal leaf beetles to boards on which they will be trapped. You will compare four colors: blue, green, white, and yellow. The response variable is the count of beetles trapped. You will mount one board on each of 16 poles evenly spaced in a square field, with four poles in each of four rows. Sketch the field with the locations of the 16 poles. Outline the design of a completely randomized experiment to compare the colors. Randomly assign colors to the poles, and mark on your sketch the color assigned to each pole. Use table B and start at line 115
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
so how is that problem done ?? its confusing me a little ??
any help would be great.
Thanks for all the helps guys... it really helped me
dugums
Better, Faster, Stronger
Apr 10, 2007
699
Chicago, IL
answer is B
Answer is B, but your probabilities are still wrong.
First pull: 52/52
Second pull: 39/51
Third pull: 26/50
fourth pull: 13/49
Sil
Evil Empire
Jan 13, 2008
340
Milwaukee/Chicago
-=Fonz=-;1019946 said:
so anyone know how to do that last problem with the colors.. no idea whats it is asking ?
You're basically designing a completely randomized experiment using whatever random digit table you were provided, number the 16 poles 0-15, or 1-16 or realistically anything you want, then assign a set of digits to each color, go through your table and assign each pole a color. Then put it in a sketch.
dugums
Apr 10, 2007
699
Chicago, IL
The problem is actually giving you step-by-step instructions of what to do. Just follow them. If you don't get it, read it again. Don't over-think these things. If you don't know what it's asking, just start working on it.
Post your work and we'll correct you.
You aren't going to learn anything by us posting the answers.
