somewhat the car is super rich right now..... the main problem is that the map ecu doesn't read below -10 psi and has no cold start enrichments so when the car is below normal opperating temp it does it just by reving, the best is during pulls when it blows fireballs between shifts.
meh... a little bit when the car is cold it idles at like 11-12 af and slowly leans out as it warms up... once at normal operating temp it idles 14.5-15, id rather be rich then lean any day, everything has only 2000 miles on it, and its a built motor so unhealthy... no, rich... yeah due to the setup
