List of abbreviations (merged)
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Hey folks - we used to have one of these, but I cannot find it anymore. Methinks it was eaten by the server crash, so, it's time to fire it up again.
Post or PM your input and I'll add it to the list in the first post. Eventually, we'll copy it into a thread in the Info forum.
AFM=Air Flow Meter
MAF=Mass Air Flow meter
MAFT=Mass Air Flow Translator
ISC=Idle Speed Controller
PCV=Positive Crankcase Ventilation
SST=Special Service Tool
polobai
Orlampa
tps-throttle position sensor
tems-toyota electronically modulated suspension
afpr-adjustable fuel pressure regulator
7
7m-gte_power
Guest
thanks u im new and didnt know what everyone was talking about im going to save this ok well peace
Kerry
TONY!
Habitual Supra Killer
Tonyland
^ not a technical term or relating to Toyota
IMO in my opinion
IIRC if i remember correctly
FWIW for what it is worth
LOL laughing out loud
ROFL rolling on the floor laughing
LMAO laughing my ass off
ROFLMAO rolling on the floor laughing my ass off
plenty more but those MAY be outside the realm of this discussion since its not a tech abbreviation--but then you did not know it wasn't a tech term, so it is cool.
Then there are chat room abbreviations that you only see there...
Mo87NA said:
BHG=Blown Headgasket :cry:
LOL Mo87NA
drunk_medic
7Ms are for Cressidas
Woodstock, GA
Here's a good start:
SNAFU - Situation Normal; All F'd Up
FUBAR - F'd Up Beyond All Recognition
PITA - Pain In The Ass
JZ - Referring to the JZ family of Toyota/Yamaha Engines [ie: 1JZ(GE, GTE, FE, FSE), 2JZ(GE, GTE)
7M - Last of the M family of engines featured in the Toyota Supra and Toyota Cressida. [ie: 7M(GE, GTE)]
AFAIK - As Far As I Know
ABS - Anti-lock Brake System
SRS - Supplemental Restraint System
IC - InterCooler
SMIC - Side Mount InterCooler
FMIC - Front Mount InterCooler
TMIC - Top Mount InterCooler
n2o - Nitrous Oxide
NOS - Nitrous Oxide Systems; Holley's brand of n2o, or what ricers call their NX or Zex system
CT-26 - Single Turbocharger which comes standard on the 7M-GTE and 3S-GTE engines
CT-12a - Twin Turbochargers which run in parallel and come standard on the 1JZ-GTE engine
CT-12b - Sequential ["Two-Way"] Turbochargers which come standard on the 2JZ-GTE engine
TTC - True Twin Conversion; Converting the CT-12b operation from sequential to parallel.
GA70 - Chassis code for 2.0GT TwinTurbo Supras with the 1G-GTE engine. Some of these came with a narrow body, some with a "wide body". Note: All US Spec cars are MA70 "widebody" models. See MA70.
MA70 - Chassis code for 86.5-1992 Toyota Supras with the 7M engines. See 7M.
MA71 - See MA70. Some cars were stamped with MA71 as the chassis code, though this has nothing different.
JZA70 - Chassis code for '89-'92 Supras with the 1JZ-GTE engine [Japanese]
TT-R - TwinTurbo-R model. JZA70 with 4:10 Torsen LSD, lightweight Recaro interior, Billstein shocks, Momo steering wheel and more.
W58 - 5 speed manual transmission on the 1986.5-1998 non-turbo Supras.
R154 - 5 speed manual transmission on the 1987-1992 turbo MA70 and JZA70 Supras.
A340 - 4 speed automatic transmission on the 1986.5-1992 MA70 Supras.
A342 - 4 speed automatic transmission on the 1989-1992 JZA70 Supras.
LSD - Limited Slip Differential
TRD - Toyota Racing Development
STB - Strut Tower Bar
ECU - Engine Control Unit
chevyeater
wastegate hose is pulled
Long Island, NY
ECU- Electronic Control Unit
EMS- Engine Management System
SIR- Supplimental Inflatable Restraint (Airbag)
COP- Coil On Plug ignition
DIS- Distributorless Ignition System
DOHC- Double OverHead Camshafts
I6- Inline six cylinder engine
NOS- Nitrous Oxide Systems (Nitrous company)
VPC- Vein Pressure Converter
EBC- Electronic Boost Controller
MBC- Manual Boost Controller
BIC DDP- BecauseICan Divorced wastegate DownPipe
Hrm.. Just Supra related? I've got a billion GM acronyms, those bastards love acronyms.
MKIIINA
Destroyer of Turbos
Plano, TX
A/F - Air/Fuel (mixture)
A/T - Automatic Transmission
ABS - Anti-lock Braking System
AFM - Air Flow Meter
ALDL - Assembly Line Diagnostic Link (a GM thing)
AVC - Automatic Valve Controller
BCC - Boost Cut Controller (GReddy FCD)
BHG - Blown Head gasket
BOV - Blow Off Valve
BPUD© - Basic Performance Upgrades Done
BTDC - Below Top Dead Center
CPS - Cam Position Sensor
DP - Down pipe
EBC - Electronic Boost Controller
ECT - Electronically Controlled Transmission
ECU - Electronic Control Unit, (a.k.a. TCCS or engine computer)
EFI - Electronic Fuel Injection
EGR - Exhaust Gas Return (Valve)
EGT - Exhaust Gas Temperature
EPA - Environmental Protection Agency (USA)
ET - Elapsed Time
EVC - Electronic Valve Controller (HKS' EBC)
FCD - Fuel Cut Defencer (HKS)
FCO - Fuel Cut Off
FCON - Fuel CONtroller
FFCD - Free Fuel Cut Defencer (mkiv term for their cheap, but effective mod)
FIPK - Filter Injected Performance Kit (K&N)
FPR - Fuel Pressure Regulator
HG - Head gasket
HKS - a company that makes high performance equipment for imports
HP - Horsepower
IC - Intercooler
JMBC - Jeff (Montigny) Manual Boost Controller
MAF - Mass Air Flow
MBC - Manual Boost Controller
MHG - Metal Head gasket
MkI, MkII, MkIII, MkIV - Mark 1, Mark 2, Mark 3, Mark 4
MSRP - Manufacturer's Suggested Retail Price
MTL - Manual Transmission Lubrication (Tranny Oil)
NA - Normally Aspirated
ND - Nippon Denso
O/D - Overdrive
OBD II - On Board Diagnostic II (an emission standard set by the EPA)
OTB - Overtake Boost (button found on the Greddy Profec-B)
PCV - Positive Crankcase Ventilation
PP - Pressure Plate
Profec-B - (PROFessional Electronically Controlled - Boost?) (GReddy's EBC)
PSSEBC - Pete Sterling Semi-Electronic Boost Controller
Rebic - Additional Injector Controller - independent of the car's ECU (GReddy)
RT - Reaction Time
RWHP - Rear Wheel Horsepower
SDF - Super "Dirt" Flow - a spoof on HKS' SMF air filter
SMF - Super Mega Flow - HKS' mushroom type air filter
SST - Special Service Tool
ST - Suspension Techniques
T/O - Throw Out (bearing)
TB - Throttle Body
TCCS - Toyota's Computer Controlled System, (a.k.a. the ECU or engine computer)
TDS - Theft Deterrent System
TDSE - Theft Deterrent System (Expanded?)
TEMS - Toyota Electronically Modulated Suspension
TNA - Turbo'ed Normally Aspirated car
TPS - Throttle Position Sensor
TSB - Technical Service Bulletin
TSRM - Technical (Toyota) Service Repair Manual
TT - Twin Turbo
VBC - Variable Boost Controller
Vf - A diagnostic line on the TCCS for EFI status
VPC - Vein Pressure Converter
VSV - Vacuum Switching Valve
VVT-i - Variable Valve Timing - intelligent
WOT - Wide Open Throttle
from SF :)
Squid699
Manic Mechanic
Chesapeake, VA
Prob a bit outside the realm of Supras - all depends on your point of view
TARFU - Things Are Really F'd Up
TAD - Travelling Around Drunk
jbsupra89t
Achieving Balance...
NJ
Far outside the realm of Supras, but in the realm of the workplace...
FNG - Fuckin' New Guy (my boss actually made that up... odd) :eek3dance
jbsupra89t
NJ
Well I'll be damned... I knew it was too clever :rofl:
While on acronyms that have nothing to do with supras, got any others?
ma71supraturbo
Redding, CA
www.geocities.com
"SOGI CAI" is the SOGI cold air induction mod (dryer hose routed to intake)
SOGI = supra owners group international
SONiC = Supra owners network in Canada
bhp = brake horsepower. Measured at the crank, this number is 12-20% higher than rwhp
SAFC = Fuel computer made by Apexi
440's = stock 440cc injectors
550's = common upgrade to 550cc injectors
PS, P/S = power steering
SSQ (bov) = hks bov
shaeff
Kurt is FTMFW x2!!!!
11
Around
IJ. said:
ICS: Idle Control Solenoid
IJ, are you talkin about your non toyota unit again? haha.
we have an ISC (idle speed control)
-shaeff :wave:
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Maybe this should be sticky'd?!
There are some acronyms that people use that leave me scratching my head. Call me a newb; but, man I need some of these things defined!
Plus, I'm sure our new people would like some insight also...
I'll start it off with just a few.
DP = Downpipe
FFIM = Front Face Intake Manifold
IC = Intercooler
YM = Yo Mamma :biglaugh:
Take it away guys and gals... :)
