does any one know i it is possible to run the lipp fuel rail and jtube block off plate with a stock fuel system, cuz i pulling my rail of to change a leaking injector i figured i would by pass the jtube and switch rails while i was at it
Stretch said:So, this means you won't be running an aftermarked fpr? If so, then I think you should keep the j-tube in place until you decide to run one, as it contains the bottleneck which is the factory fpr.
eric
cruzinbill said:does any one know i it is possible to run the lipp fuel rail and jtube block off plate with a stock fuel system, cuz i pulling my rail of to change a leaking injector i figured i would by pass the jtube and switch rails while i was at it
