Back in the day, on the stock engine, with 550's and the Lexus air meter.. the bolt on T4-60-1 turbo from ITS with the dual BB CHRA, and the smaller compressor housing was good for 420rwhp at 18psi. (IIRC, it was rich, about 11:1)
This was using the old HKS copy of the toyota racing housing that then was copied by Turbonetics, and sold off to various re-sellers around the world. (Cast in Mexico from what I've heard.)
Basicly, it was a bolt on turbo, that incorporated at T4 bolt on CHRA flange in a CT style hot side with internal waste gate.
I ported the heck out of that housing to improve flow, and on the stroker motor, it still would act like a stock CT26, with a distinct drop off in power above about 5k on boost at 21psi.
Highest PSI I used to run was 28. (As recorded peak by the E-01.) My Omori gauge only goes to 25psi... but has peak/warning, and the needle was well over the 25 mark, so the E-01 reading was most likely right, especially as they generally were the same readings from gauge to monitor.)
Anyway, bad gas, and 28psi on stock pistons = melted piston and broken ring land.. (thought I had good fuel in there, plus some toulene, no ping or knock, just melt down..and a noisy engine that ran like crap since the wasted piston wiped out the rings along the way, so no compression on that cyc.)
From what I've seen, the BOSS/LIPP housing is far superior to the old HKS housing I had.
It should make quite a bit more power, just from better exhaust flow alone.
