Link to a radio install walkthrough?
Charlie97L
230
Clarksburg, MD
Hey guys, thanks for answering my earlier question. The one I’m getting is ISO mount with the brackets; does anyone have a link to a walkthrough for installing the radio? I’m an experienced installer, done it professionally for a few years, and I just wanted to know basically if this was something I could knock out in 15-20 minutes when I pick up the car(minus the wiring) or if it’ll take an hour plus. Thanks a bunch. It’s an auto, by the way, if that makes a difference. Some cars it does, some it doesn’t.
Thanks
Charlie
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
It's a 15 minute job for any ex-pro installer, minus wiring. Lots of room to work in there. Not many screws - 4 in the ashtray, then two on the driver's side of the center piece - one at the top and one at the bottom, IIRC. Unscrew the shift knob, pull the clips loose starting from the top right, disconnect the electrical connections, pull it off, and voila, you are in.
Remember to buy a pocket if your head unit isn't double high.
