Line Lock kits?
frontierguy25
968
TX
Any of you guys use them? I was thinking since I'm 5spd It would help me load the car a little bit before the launch and help with doing some burn outs. It's not that expensive and pretty easy to install.
Just seeing if you guys have had any success with these?
shaeff
Kurt is FTMFW x2!!!!
11
Around
Grab a flaring tool, some line, and a line lock and make the kit yourself. It'll be MUCH cheaper that way! I *think* Titan offers a kit. It's very expensive. I'd prefer to build my own.
slowpra na-t
Permanently Banned
Oct 16, 2008
132
murrieta ca
they work really well for doing burn outs... i've never used it to put a load on the engine because i dont want to destory my clutch anymore than it already is.
frontierguy25
968
TX
There are some on Summit for about $60, and there is a local shop that can supply me with the parts.
I don't think that it would hurt it all that much.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
If you want to load the engine before launch, get a 2 step. If you want to lock up your front tires for the burnout, get a line lock.
joliroger4
Flying Dutchman Pilot
Apr 4, 2005
264
New Jersey
www.geocities.com
This is everything you need to do the job in -3 AN braided stainless high pressure line. A DIY plugnplay kit relatively cheap, much cheaper than the kits out there. However it is the summit line lock. A much higher quality solenoid is the hurst roll control, but is also much more expensive. I run the summit in both supras and the hurst in the truck.
http://store.summitracing.com/partd...UM%2D760002&N=700+-46908+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EAR-592032ERL&N=700+0&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS-641411&N=700+0&autoview=sku
X2 http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS-642441&N=700+0&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EAR-63010112ERL&N=700+0&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EAR-63011714ERL&N=700+0&autoview=sku
You will need a momentary switch of your choice. I left that out since some people might want different styles of switch. You may also need 2 1/8" npt plugs on the solenoid. My line lock only had an inlet and outlet which did not require plugs, however, summit is now saying it has 3 outlets which would require two to be blocked.
darkspeed
138
Montgomery, AL
www.pbase.com
You can look at mine at TX; I bought a brake line segment and two inverted flare adapters from O'reillys for about $7, bent the line segments, and flared the new lines.
I'll try to get pics today.
The braided lines that jollyroger is talking about will make it a little easier to route due to flexibility
