Went to the strip Saturday morning. Ran a best of a 13.6 at 105 with an ok launch. I know I could have been in the low 13s in Sac and supposedly capable of high 12s. But anyways im at 15psi with a 60-1, 550s, lex afm, mkiv pump, and SAFC 1, and a alot of other shiney stuff. Decided to try and turn the boost up alittle and see what happens. I have a Greddy Profec II. Launch spinning bad and hopping, grab 2nd and the car starts coming into boost and I watched my wideband go lean off the scale and the car jerk forward. Fuel cut? I then turned it back down to 15psi.
Are there any limitations for too much boost on my set up? I figured my car would handle atleast 20psi seeing as how i spiked 20psi once because I had to shim my wastegate because it started becoming weak. Didnt hit fuel cut then.
