hey, everytime i drive my car , when i play my cd player it dims with the music,sometimes when its not on it dims sometimes. is there any way to correct this? it dims lights, cluster etc.
No amps/subs!? Thats really weird then. If you do have an amp and sub I would suggest a capacitor. If not, try making sure the ground from your negative battery terminal to the chasis is good. Do you have a lot of aftermarket electronics? If so you may need to replace the chasis-battery ground wire with a larger guage wire.
