Lifter shim ?
silver88
12
State College, PA
I am currently in the process of setting my valve lash and my exhaust side came out good but the intake side is pretty loose. Overall I need 9 shims. I am having a hard time tracking down lifter shims. I have called my local dealer and they dont have anything, as well as some local machine shops that do head work. So I guess my question is where can I source some lifter shims from. Also I did some searching and read that you can use shims from street bikes. Is there any truth to this. Any and all info that you guys could give me would be greatly appreciated.:1zhelp:
buckshotglass
I love all your sounds.
from pm..
silver88 said:
Buckshot I am still on stock cams and I have the shims measured out in milimeters. Heres what I need.
4 - 3.10mm
3 - 3.05mm
1 - 3.00mm
1 - 2.95mm
If you can check to see if you have any or all of these that would be greatly appreciated.
I have a bunch 2.94 and under. The others are as follows..
2.95, 3.01, 3.03, 3.05, one of each.
