Lexus AFM
sathu
125
SJ, CA
Ok so I have the lexus afm pipe with the adjustable screw and I swaped out the sensor and low and behold the honeycom screen will not fit b/c it's smaller than the one on the lexus and the thing won't fit inside the accordion hose b/c it's the same size and the accordion pipe wth... It work and all but cheezy connection and I wanna get it in there like it suppose to be. Anyone have this problem and found a working solution?
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
mattjk said:
you need the LIPP AFM ;)
ok so whats the difference between the LIPP one an the lexas one,
so am I going to run into the same problem ?
I'm not sure why you swapped out the honey comb ??
couldnt you just use the whole lexas one,, "plug an play ?
Will
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
http://www.supramania.com/forums/showthread.php?t=22254
LIPP Air Fuel Meter Lexus AFM replica This is a Lexus V8 AFM Replica with the exact same dimensions as the Lexus AFM that is often difficult to find in junkyards and very expensive when purchased at a dealer. The LIPP unit has the added benefit in that it comes included with the custom air-bypass tuning screw (allowing more tuning than the Lexus AFM). This unit is made of cast aluminum and allows you to reuse the electrical box and honeycomb from your stock AFM, saving you money...
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
so f*cks sake !, now i'm lost
so can I use the one I have, its what I belive to be a lexax afm, no rplica,
is so, or cant, what do I need to change if anything ?
Will
sathu
125
SJ, CA
Well the Lexus one I have didn't come with the honeycomb probably why it's cheap and I do have a fat ass screw that I can adjust for more airflow. Any advantages of running w/ the honeycomb ?
