is it necessary to replace the stock afm w/ lexus if you do the screw thing to the stock one? cause i was reading on 935; again, and he has a lexus replica that uses your stock electronics. so just curious
shaeff said:
siman said:Either way a bigger diameter tubig with the AFM meter and the Karmaan mesh stuff on the tubes would be ideal.
...sensor operates on the principle of measuring the vortices created as air flows past a pillar shaped vortex generator...
Maybe not. Here is how it works. Air and water flow very similarly. If you ran water through the AFM, would it move exactly like it would through a tube you make? No, of course not. The AFM has an LED and reflector. The reflector wiglges as the air passes over it. This wiggle gets faster as the airflow gets faster, just like water. Sort of like a boat moving through the water. The waves move out away from the boat just like the air, as it goes over the vortex generator. That air movement causes the slight vibration of the reflector.It would work 100% without a doubt.
bcg04 said:That's a great write up. I also really liked the way you did the injector clips/wiring.
In addition I think the walbro fuel pump (to help with fuel pressure) and removing the J-tube and stock FPD may help for a more flowing system. I didn't see that in there but maybe I missed it But then again you were trying to focus mostly on the Lex and not the entire system.
Nick M said:Maybe not. Here is how it works. Air and water flow very similarly. If you ran water through the AFM, would it move exactly like it would through a tube you make? No, of course not. The AFM has an LED and reflector. The reflector wiglges as the air passes over it. This wiggle gets faster as the airflow gets faster, just like water. Sort of like a boat moving through the water. The waves move out away from the boat just like the air, as it goes over the vortex generator. That air movement causes the slight vibration of the reflector.
