lexus afm and 550s
supra8903
512
Latham, NY
i have a lexus afm and 550s, i want to know if i need a afpr or a larger pump. Im on the stock turbo now, and i want about 14.5psi, will i be safe with just the 550s and the lexus afm. I will also have a safc II in about a month. Will i be ok till then.
Joe
sleepersupra
i hate this car
Nov 5, 2005
311
Broken Arrow, Ok
Joe
i don't know about safe but i had 550's and lexus w/ no pump and it ran real dawgish....if thats a word. so yes to the pump and i have a afpr and it's not on but to tune it you need to have as far as i know.
someone else will chime in
MKIIINA
Destroyer of Turbos
Plano, TX
you dont NEED it right off the bat. however i recommend you do it. i have been running the lex 550 setup for sometime now w/o the pump and reg with no issues and im still rich as hell!
shaeff
Kurt is FTMFW x2!!!!
10
Around
short answer: change the darn fuel pump. it's only $99 shipped from ebay, and is damn good insurance that your stocker doesn't die on you.
-shaeff
Jspec7m88
1,583
Nappy City
Well I've been trying to search for the past hour on anything about the Lex/550's combo and what the pros/cons are to using one without the other and what not...There really does need to be a sticky...
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i have lex afm and 550's and a SAFCII and stock pump. ran 16 psi daily on the stock ct and i was still 10.x:1 AFR.
shaeff
10
Around
^ you're brave. don't be surprised if your motor grenades itself due to lack of fuel after the stock pump dies.
and jspec, yes, i'm referring to the aforementioned pump.
pro- it raises fuel cut
con- it's limited in adjustability as far as tuning alone. add in an SAFC and an AFPR and you can hit 500rwhp on this setup.
-shaeff
tonysupra
224
CT
i recommended getting both the larger pump and afpr. I have the safcII also but i didn't want to cut corners. with this set up, like shaeff said, it's capable of high numbers.
