Lexes arf tuning
DGmk3
DomesticMan sucks
May 15, 2006
122
Superior WI/(Duluth MN)
JustAnotherVictim said:
If you have the 550's on your car along with the lex the a/f ratio should be close to stoic. You'll still need a piggy-back to fine tune your mixtue.
I doo have 550's and the lexes but my car runs horribly rich I'll be installing an safc soon but for now I was trying to mess with that screw to try and help it
dbsupra90
toonar
indiucky
well here is the thing. w/ the 550cc + lexus afm it should run close to stock. problem is, stock is uber rich, esp 4500 rpm+.
with my 580cc injectors i ran w/ the screw all the way out. be advised, this is unmetered air, which is why it leans the mixture out. please dont just turn the screw all the way out from the get-go. im saying this as example purposes only. it will lean the entire mixture out and if you dont have the proper metering devices you can run into trouble in a hurry.
if you are planning on getting the afc soon, i would just leave it where it is and adjust it while on the dyno w/ a wideband. if you do already have a wideband, by all means you can adjust it to see how it behaves. but always do tuning in small steps.
DGmk3
DomesticMan sucks
May 15, 2006
122
Thanks alot I think my sensor may be bad and I'll check it tomorrow .....very informative answer BTW
DGmk3
DomesticMan sucks
May 15, 2006
122
Thanks justanothervictim I just went outside and pulled my codes and it came back aif flow meter I guess if you want your car to run right you should make sure you have the right afm installed haha I had the lexes one on I threw my toyota afm back on and the car runs mint I feel stupid thanks again you guys rule
dbsupra90
toonar
indiucky
yep they are the same part. the last digits are different since they are "updated" from being newer.
id say its a good chance the lex was bad from sitting out in the weather at the boneyard.
glad you got it sorted. the a/f must have been a lot worse than i thought you were saying.
DGmk3
DomesticMan sucks
May 15, 2006
122
thanks yeah the car wouldn't even Idle so I'm sure the other sensor was completely wasted
