lex AFM in GE
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
is it possible to use the shell of a lex afm with the GE electronics, like with the turbo, on our non turbo cars. reason being, i want to run more fuel if i go with a higher comp and ide rather not go MAFTPro and run speed density. or can i run 440s with the GE AFM. thx in advance
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
as Nick said, nope.
Totally different opperating principal.
You should be fine with all the stock equipment. You are most likely running a tad rich as it is and to rich causes a lose of power anyways. 99% of the time a N/A engine will make its best power when the AFR is somewhere between 13:1 to 13.5:1.
drjonez
the motor city
www.4cefed.com
1. lex AFM won't work (as already stated!).
2. no need for MORE fuel on your GE. 330s are already overkill....lean that beast out!
