alright first things first, the set up is:
lexus AFM with adjustment screw
550cc injectors
aeromotive AFPR
walbro fuel pump @ 12v constant
heres the problem; i just got the car running again and have about 700 miles on it since then. ive noticed that while cruising my EGTs get kind of high for my tastes. at ~70MPH and ~3k rpms im seeing EGTs close to 1400F (the probe is pre turbo at the collector. at WOT the EGTs stay a little below 1400 and dont seem to go any higher (cant really keep a close watch on the EGT gauge at 100+ MPH). if i were to increase my speed while cruising, the EGTs continue to climb past 1400, i dont know how far past they will go because at that point i get a little nervous about melting the motor down.
also, i had my base fuel pressure set to ~ 37psi. once fully warmed up the car would miss pretty constantly. i lowered the base fuel pressure to ~32-33 psi and the idle improved. my EGTs didnt change with that change.
so i hooked up the volt meter to see the fuel trim (VF signal) and it is pegged at 5v.
i reset the computer and the vf signal changed to 2.5v (no adjustment) then after a few moments it jumps right back up to 5v. base fuel pressure adjustments seem to have no effect on this. and tried upping the fuel pressure to 40psi and there is no change in the VF signal, the car just idles terribly (which is expected..)
am i wrong in thinking i should be able to get the VF signal at idle close to 2.5?
as far as i can tell (without a second set of eyes) im not loosing fuel pressure at higher RPMs or under boost.
i also havent pulled the plugs yet to get a reading from those.
could i have an obstructed or kinked fuel line possibly? would i still have proper fuel pressure if a hardline was kinked?
550cc injectors
aeromotive AFPR
