Let's talk High Flow Cat
Supra469
495
Maryland
Which one do you have how do you like it.
Also, for those of you using test pipes chime in also.
To ensure I continually pass my emissions I have to have a cat installed.
Would like your pros/cons size brand & price and pic would be a bonus! Thanks.
mkIIIman089
Ohio
I bought (and will again possibly) Random Tech. It looked good, can't comment on its performance.
hellraiser456
130
canada
i got my cats removed with a full custom DP.....and well...i would never put them back in....we don't have any strict emissions here so they would never check.
figgie
Twin Cities, Minnesot-ah
had a Random Tech 3" metal substrate cat. Worked like a champ.
You know that brings up another point. Everyone always says the cats, whether aftermarket or OEM are restrictive yet have to see ANY single dynos posted to prove that fact.
dbsupra90
toonar
indiucky
i gained 115rwhp when i took off the cat. oh wait, i upgraded the turbo at the same time so maybe that isnt a fair comparison.
seriously tho, i have a mag article here where they did a hi flow cat shootout. they flow tested several different oem and aftermarket cats, as well as straight pipe. if anyone cares, i'll see if i can find it and post the numbers. if i recall, the random cat was the best. i believe it flowed <5% less than straight pipe.
but, i have yet to see dyno comparisons.
lagged
1991 1JZ
new rochelle
there is no such thing as a "high flow" cat. the only thing you can do to improve the flow is to get a cat with a larger ID.
figgie
My happy ass is going to be laughing when all of a sudden Florida does bring back emissions (for you young tikes emissions was taken off from Florida in the early 90's).
Why would florida do that you ask?
Well they are running out of options to make money ;)
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
Then move to IL :biglaugh: no emissions here. My car's not drivable yet so I can't offer my opinions on a cat. I didn't have one on my last three cars!
-Chris
Supra469
495
Maryland
For those that do have a cat, whether your car is runing or not, don't forget to list the brand and price (if you remember it) lol.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I have a 3" Cooleeze testpipe with the built in hangers for the stock mounting locations. I've heard many people complain about the hangers not fitting, but I've had no problems, it fit like a glove. One stipulation I do have though is that any cooleeze flange, be it on a test pipe or downpipe, is shaped a little differently than the standard 3" flange found on most test pipes, DP's, and catbacks, but they seal fine. I also wish Greg would have included crush gaskets instead of the paper ones.
figgie
Keep in mind
that Cats can have two material inside
the ceramic substrate one which is more dense. Or the metal substrate one which is higher flowing. The Random Tech Cat I have IS CARB legal (have to look the number up at home).
P.S it is also for sale as I ahve a 4 inch one now :)
MRSUPRA
838
Maryland
I was running an RT high flow CAT for a while. I switched to an equal size test pipe and my boost jumped from 18 to 20psi with no other changes. That alone tells me that the RT CAT was restricting flow. I will never go back to catolitic converter unless its Emissions time..
Blade2001
61
TX
I am running 3" RT cat.. never passed emissions ever since!!! may be it has to do with 550s and Lexus AFM..
figgie
psst
cats have to be in the stioch range for them to be effective. And actually, optimally it has to be going from stoich or close to to lean and back and forth. This way the cat can actually do its work.
