let me make sure this is right......
supra8903
512
Latham, NY
Installing a 2j.......
Needs:
2jz astro clip
bic mounts
1j bellhousing
1jz flywheel
1jz harness
1jz ecu
mid sump oil pan
Install:
same as a 1J
cut spedo hole
hook it up and go
Questions.........???????
Is it really that simple, I undestand I would need IC pipes, I have electric fans, hammer for the firewall.
also, what is the power limit with running the 2j off 1j electronics
anyone please put in their 2 cents
thanks
tissimo
Stock is boring :(
Melbourne, FL
yes you can go that route..
as for power, supra nick is running 400+whp on the stock twins (usdm) at 16 psi.. he does have 264 cams though..
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
not that i see
looks like you got it
as you mentiond fan and IC and pipes
so yea looks about right.
tissimo
Stock is boring :(
Melbourne, FL
you only need the bic mounts if you have a pre 89 xmember(square mounts).. if you have the 89+ xmember (round mounts) you can use the jza70 brackets..
The Reaper
Jan 10, 2006
1,909
Florida
^^^oh yea
if its going in the maroon car shown then you might wanna check cause the 89's are iffy some had old Xmembers others had the newer Xmembers
Install:
same as a 1J
cut spedo hole
hook it up and go
thanks
If only it was that easy...................You can do it, but be prepared to cuss a little and then cuss a little more. Hopefully yours will go smooth. I feel mine went as smooth as I could hope for and was still a pain in the ass...............:biglaugh:
Mines is a 1jz, the smaller illegitimate brother to the 2jz.
