Lean spot at 3400-3600rpm
Sep 19, 2011
510
Des Moines, IA
Well I have been trying to sort out a lean spot I have been having for quite some time now. Any help with this would help. I may try to get a video up some time soon too.
First my mods.
-Lex AFM
-560cc inj (flow tested)
-AFPR 43psi
-manual boost controller
-3" elbow back exhaust no cat
-57 trim DM ct upgrade
-255 Walbro pump
-SAFC2
I am on the stock IC and piping
Using AEM boost gauge, and wideband
Well here is the deal, at idle 800rpm all through to 6250rpm the car acts normal. The only spot where it is not normal is in the little range from 3400 rpm to 3600 rpm. This makes the car very unstreetable for the little mods that are done to it, because that is right where this turbo starts to spool well.
What it is doing under low throttle (1% to 35% or so) it will drive normal up to around 3300rpm, and just start leaning out, and it will peg my wideband at full lean around 3400rpm, then after 3500-3600rpm it will come back down, and drive normal through the rest of the RPM range.
Under higher throttle (above 35% or so) it will be fine up until around 3300rpm and lean out some as I am coming into boost (13 or 14 AFR), then at 3400 it is at around 16 AFR and around 3500 it will start to come back down to normal (10.5 AFR or so).
The car seems to hold boost fine, I have to run a boost leak test on my car still, but it is running lean not rich, and the lean spot is when the turbo is starting to spool and building boost. So this should not be the problem. Also I did replace some of my old cracked hoses, so there should also be no unmetered air coming in.
So my question to you all is why would my car be doing this? I am thinking it may be the ecu, or the fuel system for some reason.
What I have done to trouble shoot this problem.
-Messed around with the SAFC to add fuel (doesn't help lower AFRs much)
-Added fuel pressure via AFPR (didn't help)
-Turned in the stock lexus AFM tuning screw all the way (lean spot becomes less noticeable but is still there and under low throttle will still lean out all the way)
-tightened, and re-tightened, and rechecked all of my clamps on the stock IC piping (didn't help)
-replaced any split hoses (didn't help)
-took off my SAFC completely (didn't help)
-tightened my MBC all the way (stock boost settings, and didn't help)
-took my MBC off and attached just a regular vacc line (didn't help, just lost power)
The only thing I have not done that I think may solve this problem is to put my stock 440cc injectors back in with the stock MAF and see if that my fix it for now. The only problem is I would have to re wire for the other injector clips again, that is why I have not tried it yet. This is next on my list, and if it solves it I will drive it like that until I can get a standalone.
IndigoMKII
2,181
Madison, Virginia
First my mods.
-Lex AFM
-AFPR 43psi
-255 Walbro pump
-SAFC2
Forgive me but I think this lean spot you're getting is from not having done the 12v MOD for the fuel pump. I could be wrong though..
toyotanos
What will we break today?
2,842
Coon Rapids, MN
Another thing that comes to mind is if you have deleted the fuel pulsation damper. I had a lean issue with my 720's at ~3k rpm, went away with a damper.
shipkiller
398
Quebec
I believe the 9V is only at idle
Sep 19, 2011
510
Des Moines, IA
I did delete that. Hopefully I didn't throw any of them away off my other fuel rails. I may have to try that. Why would that cause this tho.
toyotanos
2,842
Coon Rapids, MN
When the fuel injectors open, the pressure and fluid in the rail shifts slightly, it's called fuel pressure pulsation. There are frequency peaks resulting from that can affect the fuel moving through the injectors if it gets bad enough. It's the reason the pulsation dampers were installed- to prevent said pulsation from occurring inside the fuel system.
san supra
833
san antonio
a little side question i hope...why do people delete it?
sorry i have no answers for this thread but im interested in case i run into the same prob...
egr delete? heard it could cause this
Sep 19, 2011
510
Des Moines, IA
Still have EGR, but I am going to be taking it off asap.
Ill see if I can't find my old damper and put it back on. hopefully that is the problem, but that would be quite odd.
Like most things that get deleted, people don't understand the function.
airhead04
1,489
Lima, Ohio, United States
So true. I've deleted stuff over the years bc I wasn't knowledgable in this car enough. Now working on these cars for a while, I realize things are there for
A reason. ;)
